Understanding How Robot Mowers Work
Key Features of Robot Lawn Mowers
Autonomous navigation: Uses sensors, GPS, or boundary wires
Cutting system: Often features multiple small blades or rotary blades
Battery powered: Recharge automatically via docking stations
Rain sensors: Many pause during wet conditions
Scheduling: Operate on customizable mowing schedules
Sensors and Navigation Systems
Ultrasonic sensors for obstacle detection
Tilt and lift sensors for safety
AI algorithms for mapping and optimizing mowing patterns
Can Robot Mowers Cut Tall Grass Effectively?
Challenges Robot Mowers Face with Long Grass
Clogging: Tall, dense grass may clog the blades or wheels
Battery drain: Long grass creates resistance, and having the mower to go back and forth on the same spot over and over again reducing battery life
Missed spots: Navigation may be hindered by uneven terrain
Blade wear: High stress leads to faster blade dullness
Performance Comparison: Long vs Short Grass
| Feature | Long Grass | Short Grass |
| Cutting Efficiency | Moderate to Poor | High |
| Battery Usage | High | Moderate to Low |
| Lawn Aesthetics | Uneven, streaky | Clean and uniform |
| Maintenance Requirement | High | Low |
Manufacturer Recommendations on Grass Height
2-3 inches (5-7.5 cm) for most robot mowers
Anything taller should be reduced manually first
Check your user manual for model-specific guidance. For example:
Tips to Help Robot Mowers Handle Long Grass
Gradual Cutting Strategy
Pre-Mowing with Traditional Tools
Adjusting the Cutting Height
Features to Look For In Robot Lawn Mowers
High torque motors
Large cutting deck
Wide cutting height range
Rain sensors & self-cleaning
AI navigation for dense patches
Pros and Cons of Using Robot Mowers on Long Grass
Pros
Automates lawn care once initial prep is done
Maintains consistent lawn health with frequent cuts
Saves time and effort
Cons
Requires manual prep for overgrown lawns
Can damage the mower if grass is too tall
Not ideal for sudden, infrequent mowing needs
Maintenance Tips After Mowing Long Grass
Blade Cleaning and Replacement
Clean blades after every session in long grass
Replace dull blades more frequently
Battery and Motor Checkups
Ensure the motor isn’t overheating
Charge fully before long sessions
Look for signs of battery strain (e.g., short runtimes)
Safety Precautions When Using Robot Mowers on Tall Lawns
Remove obstacles like sticks, toys, and rocks. Although the mowers can navigate through them, this would just delay the overall working time and result in an uneven cu.
Monitoring the mower during the first few sessions helps ensure that the mower is not facing any issues, problems or is getting stuck somewhere.
Ensure children and pets are not nearby during the operation
Never lift or tilt the mower when it's running as it can expose the blades while they are spinning, which can be dangerous for you or anyone nearby.
Expert Insights: What Professionals Say
“Robot mowers are like a toothbrush — use it daily, and you’re good. Skip a few weeks, and you’ll need a deep clean first.” – Jake Monroe, Turf Specialist
Common Mistakes to Avoid
Letting grass grow too tall before first use, as every company has a instruction about the height of grass that the mowers can comfortably cut.
Forgetting to raise the cutting height can be a real problem as it tells the mower about the outcut you are expecting and the height of grass you need from it.
Expecting instant results in one session
Not cleaning blades after thick grass cutting, this can cloge the blade or even dull the blade if grass remains stuck to it.
Can robot mowers cut very tall grass?
Will long grass damage my robot mower?
Should I manually mow before using a robot mower?
How often should I mow to avoid overgrowth?
What happens if my mower gets stuck in tall grass?
Are there robot mowers made specifically for tall grass?
