Dual Safety Protection: Explaining Overload Sensors and Shear Pins
Yarbo snow blower
Proper snow blower maintenance isn’t just about keeping your equipment clean it’s about ensuring safety and extending the machine’s lifespan. When a snow blower encounters compacted snow or hidden obstacles, the auger or impeller faces extreme stress. Without essential safeguards, this stress can cause costly damage, such as burned-out motors or broken components.
Two critical components often overlooked in this protective process are shear pins and overload sensors, which function together as a dual safety mechanism. Yarbo, a pioneer in autonomous snow blowers, integrates both systems to protect users and machines from unnecessary damage or costly downtime.
Let’s explore how this safety duo works, why it’s critical for effective snow blower maintenance, and how Yarbo’s engineering makes it smarter and safer for winter operations.
Why Snow Blower Maintenance Matters for Performance & Safety?
“Dual safety protection” refers to the combined action of mechanical and electronic safeguards. This layered approach ensures reliability even in deep or compacted snow conditions.
  • Mechanical Protection: Shear pins are inexpensive fasteners designed to break under excessive torque, preventing damage to the auger and drive shaft. They act as your first line of defense.
  • Electronic Protection: Overload sensors are intelligent electronic sensors that automatically monitor resistance and current flow. They detect excessive strain and stop the motor before damage occurs. These sensors are the High-Tech Guardian.
Together, they create a fail-safe system that prioritizes longevity and user safety.
What “Dual Safety Protection” Really Means
  • Mechanical protection comes from shear pins that break under excessive torque, preventing damage to the auger and drive shaft.
  • Electronic protection comes from overload sensors that automatically detect strain and stop the motor before damage occurs.
yarbo snow blower in heavy dense snow
Common Risks When Maintenance Is Neglected
  • Broken auger blades from frozen obstructions
  • Burned-out motors due to overload
  • Reduced clearing efficiency
  • Sudden operational failure mid-storm
Regular inspections and part replacements, like checking shear pins and testing overload sensors, are essential parts of snow blower maintenance to prevent these issues.
Understanding Shear Pins: Your First Line of Defense
What Shear Pins Are and How They Work
Shear pins are small, inexpensive fasteners designed to hold the auger to its drive shaft. They’re engineered to snap when torque exceeds a safe limit—essentially sacrificing themselves to protect the auger gearcase and motor.
In Yarbo’s snow blower modules, these pins are precision-tested to ensure they break at exactly the right pressure, preventing serious mechanical failure.
When Shear Pins Fail: Signs and Symptoms
Common signs include:
  • Auger not spinning even though the engine runs
  • Uneven snow discharge
  • Metallic rattling or partial rotation
If one pin breaks, it’s crucial to replace it immediately—running the blower with missing pins puts uneven stress on the drive system.
Replacing Shear Pins: Step-by-Step and Best Practices
Turn off and disconnect power.
  1. Inspect the auger area for ice or debris.
  2. Remove the broken shear pin and cotter pin.
  3. Align the auger holes and insert a replacement shear pin (OEM parts recommended).
  4. Secure with a new cotter pin.
Yarbo offers dedicated Shear Pins & Cotter Pins Sets designed for its snow blower modules. Using genuine Yarbo snow blower replacement parts ensures compatibility and maintains warranty protection
Understanding Overload Sensors: The High-Tech Guardian
What Overload Sensors Are and Why They’re Used
Overload sensors are part of Yarbo’s intelligent control system. The system detects increased current draw on the motors. Yarbo automatically adjusts its speed to reduce strain. In cases of potential overcurrent, it will slow down or temporarily stop. This protects the motors and electrical components from damage.
Why Overload Sensors + Shear Pins Provide Real Protection?
The benefits of combining these mechanical and electrical safeguards include preventing permanent damage, extending motor and gear life, reducing downtime, and protecting user safety.
We often see the real-world value of this system. Consider John, a homeowner in Minnesota, who experienced the same obstruction scenario with two different machines. His older, traditional machine’s auger seized, resulting in over $600 in repairs. After switching to the Yarbo autonomous system, the obstruction triggered the dual protection: the shear pins broke, and the overload sensor instantly cut power.
The machine restarted safely after replacing just a $5 pin.
This scenario perfectly illustrates the value of dual safety protection—it offers affordable prevention that safeguards your long-term investment.
How Overload Sensors and Electronics Integrate
Unlike traditional systems relying solely on mechanical fail-safes, Yarbo’s autonomous snow blowers combine smart software with hardware protection. The overload sensors connect to a control board that dynamically adjusts travel speed based on the motor's current draw ideal for adapting to varying snow densities.
Yarbo snow blower sensors
Troubleshooting Overload Sensors
If your blower stops unexpectedly:
  • Check for obstructions in the auger or chute.
  • Inspect power supply and connections.
  • Restart the system after clearing any blockages.
Yarbo’s app also provides diagnostic feedback, letting users quickly identify whether the overload system activated for protection.
Integrating Both: Why Overload Sensors + Shear Pins Provide Real Protection
Scenario: Heavy Snow, Jammed Auger, and Dual Protection
Imagine your snow blower meets a hidden chunk of ice. The torque spikes instantly.
  • The shear pins snap first, disconnecting the auger.
  • The overload sensor detects the surge and shuts off the motor.
This quick sequence prevents both physical and electrical damage—saving hundreds in potential repairs.
Benefits of Combining Mechanical + Electrical Safeguards
  • Prevents permanent damage
  • Extends motor and gear life
  • Reduces downtime
  • Protects user safety
How Yarbo’s Modular Design Supports Both Layers of Safety
Yarbo’s modular snow blower integrates overload sensors directly into its drive system, while its replaceable shear pins act as frontline protection. This layered approach ensures reliability even in deep or compacted snow conditions.
As part of Yarbo’s Smart Yard Ecosystem, this design philosophy puts durability and intelligence at the heart of every maintenance task.
Snow Blower Maintenance Checklist for the Winter Season
Maintenance Task Frequency Purpose
Inspect shear pins Before each heavy use Prevent auger damage
Test overload sensor Monthly Ensure electronic safety
Lubricate moving parts Every 10 hours of operation Reduce friction
Clean chute and auger housing After every use Prevent buildup
Replace belts if frayed Seasonally Maintain drive efficiency
Charge or inspect battery Before use Ensure consistent power
Store in dry location End of season Prevent corrosion
Keeping up with these tasks ensures smooth operation and reduces the risk of mechanical failure.
Replacement Parts You Should Stock for Reliable Maintenance
Essential Snow Blower Replacement Parts
According to Yarbo’s official blog, these are must-have items for winter readiness:
  • Shear Pins & Cotter Pins
  • Scraper Bar
  • Skid Shoes
  • Snow Track
  • Auger Blades
Each component plays a role in snow blower maintenance, ensuring smooth and safe performance.
Why OEM Parts Matter
Using non-OEM parts might seem cheaper, but they often don’t meet torque or material specifications. Genuine Yarbo snow blower replacement parts are engineered for precision fit, reliability, and performance consistency.
Where to Purchase Parts
You can purchase authentic Yarbo replacement parts from the official Yarbo website. Always match the part number to your module and follow Yarbo’s maintenance guide for correct installation.
Upgrading to Smart Solutions: When Manual Maintenance Isn’t Enough
Autonomous Machines and Their Maintenance Differences
Traditional snow blowers rely heavily on manual checks. Yarbo has systems to detect overcurrent conditions. It adjusts operation based on snow density and resistance, includes battery management protections against overheating, short circuits, and overcharging. The system monitors its operating conditions to protect the equipment alerting users via app notifications when service is needed.
How Yarbo’s Snow Blower Module Implements Sensors & Modularity
Yarbo’s Autonomous Electric Snow Blower Module features multi-zone cleaning, GPS pathing, and intelligent overload control. This technology minimizes human error while maximizing machine protection and operational efficiency.
Cost-Benefit Analysis: Traditional vs Modern Systems
Feature Traditional Snow Blower Yarbo Autonomous Snow Blower
Maintenance Alerts Manual Smart system notifications
Safety Features Shear pins only Overload sensors + shear pins
Efficiency User-dependent Automated, AI-optimized
Cost Over Time Higher repair risk Lower maintenance costs
That’s the value of dual safety protection—affordable prevention that safeguards your investment.
Routine snow blower maintenance not only enhances performance—it protects your investment. With overload sensors and shear pins working in harmony, Yarbo has engineered a new standard of safety, reliability, and intelligence for winter operations.
By staying proactive, using OEM snow blower replacement parts, and trusting Yarbo’s smart systems, you can clear snow confidently, safely, and efficiently all season long.
Q1: How often should I check my snow blower’s shear pins?
Before every major use or after hitting an obstruction.
Q2: Can I use generic shear pins?
It’s not recommended—use Yarbo OEM parts for accurate torque calibration.
Q3: What happens if I ignore a broken shear pin?
It can cause uneven torque distribution and lead to gearbox failure.
Q4: Are overload sensors common in all snow blowers?
No, they’re typically found in advanced or autonomous systems like Yarbo’s.
Q5: What’s the best way to store my snow blower off-season?
Clean thoroughly, dry completely, and store in a sheltered area away from moisture.
Regular price $10,809.00
Sale price $10,809.00 Regular price $11,999.00
