Perimeter Wire Technology: The Old School Method
How it Worked:
The mower’s sensors detected the signal and stayed within bounds.
“No-go” zones were created using secondary wire loops.
Movement inside the boundary was randomized or pattern-based.
A labor-intensive setup that needed to be carefully planned
Limited flexibility (changing your yard layout meant rewiring, all that work all over again.)
No “awareness” of where it had already mowed
Inability to mow near the edges of the boundaries.
Limitations of Wired Systems
Labor-intensive installation – burying wires is time-consuming.
Lack of flexibility – changing your yard layout required re-installing wires.
No smart awareness – the mower had no memory of which areas were already cut.
Edge issues – difficulty trimming close to the wire’s edge.
GPS-Based Mapping: Smarter, Wire-Free Navigation
How GPS Mowers Know Where to Cut:
Mapping Mode: The user maps the boundaries via the mower’s app or a manual remote.
Virtual Zones: These digital zones are saved in the mower’s memory.
RTK-GPS: A reference station (usually the charging dock) corrects the GPS signal, ensuring super-accurate location tracking.
Smart Planning: The mower cuts methodically, covering the entire area efficiently.
Benefits of RTK-GPS Precision
Eliminates the need for physical wires.
Reduces overlap and missed patches.
Enables edge-to-edge mowing.
Improves battery efficiency with smarter paths.
PPVS: Yarbo’s Precise Positioning Vision System
What Is PPVS and Why It Matters?
Dead Reckoning: When GPS Signals Drop
Mapping: 5 m (~16 ft)
Working area: 50 m (~164 ft)
Boundaries & pathways: 10 m (~33 ft)
How Homeowners Can Adjust PPVS Settings?
Raise in-area distance for large, open yards with scattered trees → fewer pauses.
Lower boundary distance near flowerbeds or pools → added safety.
Increase mapping distance under tree cover → smoother map drawing.
Real-Life Examples of PPVS in Action
Large lawns with trees: Yarbo keeps mowing without stopping every few minutes.
Yards with flowerbeds near boundaries: Lowering boundary distance prevents overruns.
Complex gardens with pathways: PPVS ensures Yarbo doesn’t wander into sidewalks or no-go zones.
Vision + AI Recognition: When Mowers Start to “See”
Grass vs. gravel or pavement
Toys, tools, and pet waste
Trees, fences, and walls
AI-Driven Lawn Patterns for Better Aesthetics
Straight-line or diagonal mowing
Adaptive patterns for healthier grass
Edge-first mowing for sharp borders
How It Works:
Onboard Cameras: Capture real-time visuals of the lawn.
AI Algorithms: Identify grass, obstacles, edges, even pet waste.
Machine Learning: Adapts over time to mowing patterns and obstacle types.
Mowing Patterns: They can mow in the pattern of your choice to enhance lawn aesthetics.
Zoning & Lawn Memory: Smarter Planning for Big Yards
Dividing Complex Lawns into Virtual Zones
Modern mowers divide lawns into zones for better efficiency. Yarbo allows multiple zones to be defined via its app — no wires required.
Learning Grass Growth & Optimizing Cutting Frequency
Which zones grow faster
Where mowing is needed more often
When to skip mowing to prevent overcutting
Sensors for Micro-Adjustments
Bump sensors – detect unexpected obstacles.
Lift/tilt sensors – instantly stop blades for safety.
Rain sensors – pause mowing in wet weather.
IMUs (gyroscopes + accelerometers) – track slope, speed, and direction.
How Sensors Protect Safety & Efficiency?
Key Sensors Used:
Bump Sensors: Detect unexpected obstacles and reroute.
Lift/Tilt Sensors: Stop blades immediately when lifted.
Rain Sensors: Pause mowing in wet weather.
Inertial Measurement Units (IMUs): Track slope, direction, and speed.
Real-Time Decision-Making
Current GPS/RTK position
PPVS + Dead Reckoning estimates
Sensor feedback (obstacles, tilt, terrain)
Instant Reactions for Smarter Pathing
Decide where to cut next
Avoid already-mowed areas
Choose the most efficient mowing route
Safely pause when signals or safety scores drop
How Yarbo Sets the Standard in Smart Cutting?
Multi-Functional Modular Design
Lawn Mowing Module
Leaf Blower & Sweeper Module
RTK-GPS + PPVS + AI: The Triple Advantage
RTK-GPS: ±2cm accuracy outdoors
PPVS: Keeps mowing when GPS fails
AI Vision: Identifies grass, boundaries, and hazards
Yarbo Lab App: Customize Your Mowing Like a Pro
Adjust PPVS Dead Reckoning distances
Set mowing schedules per zone
Monitor GPS signal quality in real-time
Create no-go zones with a swipe
Precision Benefits: Why Accuracy Matters?
No missed patches: Every inch gets covered.
Edge perfection: Get closer to walls, flower beds, and trees.
Battery savings: Less wandering means longer runtime.
No wasted battery on overlaps
Healthier grass with fewer passes
Cleaner edges along fences, walls, and flowerbeds
No over-mowing: Prevents grass damage from repeated passes.
