Table of Contents
Storing Snowblower: Best Practices to Preserve Your Machine
Yarbo's Smart Storing Approach
Cleaning:
Just like any equipment, your Yarbo Snow Blower module should be cleaned of snow, salt, and dirt with warm water and mild soap. Ensure it's dried completely to prevent rust, as its IPX5 waterproof rating ensures it can handle wet conditions.
No Fuel Hassles:
This is where Yarbo truly shines. Unlike gas-powered machines where stale fuel leads to carburetor clogs and damage, Yarbo runs entirely on a 36V/38.4Ah lithium-ion battery. This means no draining, no stabilizers, and no worries about gasoline degradation.
You simply ensure the battery is at an appropriate storage charge level.
Modular Storage Advantage:
One of the biggest pain points for large yard owners is managing multiple bulky seasonal tools. With Yarbo, you have one Yarbo Core unit that integrates with various modules. This means your garage isn't cluttered with separate mowers, blowers, and snowblowers.
You store the compact Snow Blower module separately from the Core, freeing up significant space. It's the ultimate "one solution" for year-round maintenance, reducing equipment purchase costs and saving storage space.
Durable Design for Any Environment:
Yarbo is built for North America's harshest conditions, with extreme temperature resilience from -25°C to 45°C, and even operation as low as -40°C with heating modules when powered on. Its rugged, heavy-duty build means you have less to worry about regarding environmental wear during storage.
While a breathable cover is still recommended for dust protection, the core unit and modules are designed to endure.
How to Winterize a Snow Blower: Step-by-Step Guide
Drain or Stabilize Fuel – Either run the tank empty or add fuel stabilizer to prevent carburetor buildup.
Change the Oil – Fresh oil protects the engine from corrosion during storage.
Check Spark Plug – Replace if dirty or corroded to guarantee a strong start.
Inspect Belts and Auger – Look for cracks, frays, or worn parts. Replace if necessary.
Lubricate Moving Parts – Apply lubricant to bearings, chute, and cables to prevent seizing.
Clean Thoroughly – Remove all salt and snow residue to avoid rust.
Store Correctly – Cover and place in a dry, sheltered area.
Winterizing Made Simple with Yarbo
No Fuel to Drain or Stabilize: As an electric robot, Yarbo completely eliminates steps 1 (Drain or Stabilize Fuel) from traditional winterization guides.
No Oil Changes, No Spark Plugs: Yarbo's advanced electric motors mean there's no engine oil to change (step 2) or spark plugs to check or replace (step 3). This saves you time and money on fluids and parts.
Simplified Inspections: You'll still want to inspect belts and the auger (step 4) for any wear or damage, just as you would with any heavy-duty equipment. Yarbo's robust, heavy-duty build is designed for durability, but regular visual checks are always good practice.
Lubrication: While Yarbo's advanced design minimizes many mechanical parts found in traditional snowblowers, lubricating any exposed moving parts (step 5) like the chute mechanism is a good habit to prevent seizing, ensuring smooth operation.
Thorough Cleaning: Cleaning all salt and snow residue (step 6) is vital for any snowblower, including Yarbo, to prevent rust and maintain its integrity.
Smart Storage: Place your Yarbo Core and Snow Blower module in a dry, sheltered area (step 7). Its cold-resistant battery can work in extreme temperatures, but storing it properly helps preserve its lifespan. Remember, with Yarbo, you’re storing a modular system, not multiple standalone machines, which reduces clutter.
Extra Tips for Easy Starts Next Season
Common Pitfalls When Storing Snowblower
Leaving untreated fuel in the tank
Storing the blower uncovered in damp areas
Neglecting oil changes for multiple seasons
Using hands to clear clogs instead of a clean-out tool
Forgetting to lubricate moving parts before storage
Yarbo's Year-Round, Hands-Free Yard Care
To use a snow blower effectively, start by clearing obstacles, setting the proper chute direction, walking firmly behind the machine, and moving at a consistent pace.
Store your snowblower in a dry, covered area, draining or stabilizing fuel, cleaning components, and using a breathable protective cover.
Winterizing involves cleaning off salt and debris, draining or stabilizing fuel, changing oil, checking spark plugs, belts, auger, and skid shoes, then storing with care.
Yes—neglecting winterizing can cause clogging, hard starts, wear on engine components, and reduced performance, impacting safe and efficient use.
Check them before storing each season; replace if cracked, frayed, corroded, or worn to ensure easy operation next winter.
Yes—first use the snow blower normally; after final use, clean it, then winterize using systematic steps before storing.
